Cap n Carl
I'm in the process of putting my Bravo transom assembly back together on my bench. I installed a new stainless swivel pin and upon tightening the bolt on the steering arm, I noticed it had some side to side play. The arm can also move up and down on the pin. The arm has no signs of wear, and I can't make the bolt any tighter before it snaps! I think it just comes down to a bad design. The bolt doesn't really provide much clamping force at it's location due to the way the arm is designed. I'm not sure cast iron has much give before it breaks either. I thought of cutting a relief slit all the way thru at the back of the arm with a cutoff wheel. I don't know how much this will compromise the strength of the arm? failure at sea is not an option! Does anyone know of a solution to this problem?
Thanks. Cap.
Thanks. Cap.
