Click for Detroit Diesel manuals!
Results 1 to 2 of 2
  1. #1
    Default Need instructions for removing/replacing governer on DD 671...
    On a Detroit Diesel In line 6-71 (natural) I need to replace the governor.
    The governor plate says SWVS (single weight variable speed).
    Assembly number: 5144138.
    Idle Range: 500-900
    Drive Ration: 2:1
    The engine numbers are 6A0334150 model 1063 7000.
    Does anyone have a set of instructions for removing/reinstalling this governor?
  2. #2
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,755
    Default Re: Need instructions for removing/replacing governer on DD 671...
    Hi,
    I'm an old 71 mechanic but not so old as to have any real experience with in line engines. I only answer because no one else has yet. I remember doing oil changes and minor repair on the old in line 6-71's but that's about it.
    All of the V engines have the governor housing as part of the blower assembly and the governor is usually repaired or serviced with the blower bolted on the engine with the blower only needing to be removed to facilitate bearing replacement. If ever I removed a blower to repair a governor, I typically would also go through the blower to replace the rotor vane seals and bearings too. It takes some fairly specific methods and tools to do that and it is not easy to get it right the first time. At least I had trouble learning how to do it at first and relied heavily on the manual while learning.
    All I can recommend is that you get a proper shop manual to do this work and not rely completely on testimonials from strangers on the Internet. The operation of the governor is too critical to get it wrong and it only takes one overspeed incident to ruin the engine or hurt someone. Not to even mention the $$$ involved with making a fairly small mistake.
    I hope you find some help either here or someplace else and I wish you luck getting your engine repaired.
Similar Threads
  1. Instructions for replacing power pack 1989 Evinrude
    By CapnD in forum Johnson Evinrude Outboard Forum
    Last Post: 06-29-2016, 09:13 PM
  2. Removing and Replacing Trim/Tilt Motor
    By John Haggerty in forum Johnson Evinrude Outboard Forum
    Last Post: 03-23-2016, 11:37 PM
  3. Replacing Manifold instructions
    By nick55 in forum Mercruiser Sterndrive Archive
    Last Post: 04-08-2008, 01:39 PM
  4. Need instructions for replacing coupler on Alpha1 Gen II
    By Robb Roberts in forum Mercruiser Sterndrive Archive
    Last Post: 04-26-2007, 12:36 AM
  5. 671 governer breather tube oil discharge
    By davidrogers in forum Detroit Diesel
    Last Post: 06-11-2006, 07:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
