Results 1 to 2 of 2
  1. #1
    Default Starter problem 2001 6.0 Vortec
    I have an intermittent problem with the starter. When I turn the key I will sometimes just get a click, but the engine does not turn over. Might have to try a couple times. I have been having this problem for a while, checked, and tightened connections without a resolve. Thought it might be the battery, and after having the battery go dead in a couple days I replaced it with a brand new, fully charged Interstate. Thought sure it would fix the problem, but it has not.
    Any ideas? Someone said pissibly a bad solenoid not making good contact.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,169
    Default Re: Starter problem 2001 6.0 Vortec
    maybe the slave solenoid, especially its ground wire. the main ground at the engine being marginal could cause that behavior as well...
    Best approach is to troubleshoot the wiring with a test light or a good volt meter....from the key switch back to the starter....find a good ground and keep the ground lead on either device connected to it....
Similar Threads
  1. 2001 Mercuiser 4.3 Vortec Coil
    By scortoncreekfisher in forum Mercruiser Sterndrive Forum
    Last Post: 03-30-2016, 08:46 PM
  2. 4.3 lx vortec stalling at idle problem
    By lapdog in forum Mercruiser Sterndrive Forum
    Last Post: 08-10-2014, 07:51 PM
  3. Replies: 72
    Last Post: 06-05-2011, 07:59 AM
  4. Ignition problem new 57 Vortec
    By Capt. Rick Stallard in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 07-11-2006, 11:46 AM
  5. 1999 maxxum boat is a gen2 vortec have truck 43 vortec the same
    By rvinny in forum Mercruiser Sterndrive Archive
    Last Post: 05-21-2006, 08:42 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
