Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 9 of 9
  1. #1
    Default suzuki dt 50 spun hub or not
    hi i have a dt 50 hp when i increase power it revs and goes nowhere was told could be spun prop so went and got new one but problem still happening any suggestions would be appriciated thank you
  2. #2
    Default Re: suzuki dt 50 spun hub or not
    Does it bang out of gear? Does it go into gear at all?
  3. #3
    hi yes it goes into gear and doesnt bang out of gear goes along fine till you increase speed then over revs like when a clutch slips in a car
  4. #4
    Yes that sounds like a spun hub. Scratch a line across the back of the prop across the hub and see if it moves after you run it.
  5. #5
    i went and got a new prop and it is still the same
  6. #6
    Should have done the test first. My next question is do you have a shortshaft motor on a boat that needs a longshaft.
  7. #7
    no it was all fine till last week when the problem started
  8. #8
    You may have something going on in the lower unit.
  9. #9
    Join Date
    May 2011
    Location
    slough ,berkshire uk
    Posts
    161
    well come on, what was it ?
    dont just leave everything without putting final answer...
    far too many ignorant people as questions, get it resolved and dont bother to le us know what the problem was..
    should be banned for being so ignorant.
Similar Threads
  1. Spun Bearing Cause
    By TeamHoss in forum Marine Power Engine Forum
    Last Post: 08-08-2011, 04:40 PM
  2. Spun prop
    By dcso in forum Volvo Penta Gas Engine Forum
    Last Post: 12-16-2009, 06:34 PM
  3. Spun prop How to tell
    By snospdr in forum Johnson Evinrude Outboard Archive
    Last Post: 11-08-2009, 09:19 PM
  4. Spun PropHub
    By burnsie629 in forum Mercruiser Sterndrive Archive
    Last Post: 06-28-2009, 11:10 PM
  5. Spun hub
    By castmaster pepe in forum Mercury Mariner Outboard Archive
    Last Post: 06-12-2006, 10:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
