Hello!
I bought a used boat Wellcraft Eclipse 20 Mercruiser 5.7 carb. (# OK178561). I think it's a Mercruiser 350 MAG. ALPHA (4 BBL.) GM 350 V-8 1997. I haven't other engine numbers. Cover on carburetor does not here (write "OMC cobra").
The previous owner made a change in the motor. The wires do not coincide with the wiring diagram.
If I have correctly identified the motor, the sensor alarms must be single ended (second contact - ground).
I see a temperature sensor and oil pressure with two contacts. Ordered with 1 contact can not be install:
Does anyone help me to understand the wiring or motor model? I need it to deal with overheating or temp sensor.
I have and described the problem in another old thread: warning signal when planing. I found that guilty the temperature sensor. The engine temperature is not increasing (160-170). The engine speed is 3000 - signal appears. If run up to 4000 - the signal disappears after a few seconds. Reduced to 3000 - appears again. If lightly touching the throttle lever - signal may disappears instantly. At 2800 - no signal. At idle to.
Thermostat & gasket changed (OEM). Water pump replaced in the spring(OEM). Exhaust manifolds are not too hot - do not burn the hand. Oil in the engine clean without water. Clean lakes water last 10 years. Changed poppet valve.
I asked: will it help if I replaced the temperature sensor?
There was one response: No. Check connectors Ignition Control Module.
Thank's boat_tech for answer! I'll try to check the connectors Ignition Control Module at the weekend. Gasket thermostat I changed 2 weeks ago on a new OEM.
I noticed that the alarm depends on the trim of the boat. Lifting / lowering trim nose affects the appearance of the signal.
The signal appears when the boat comes on plane after 1-10 minutes. If I change a little-little throttle control - the sound immediately disappear, but may reappear. This is very similar to a bad contact! It remains a bit: only to find it...
And I hope that the problem is in the contacts.
Ok, it may have other ideas?
I would be glad of any help.
