WelshWizard
I have a 3-year old regularly serviced 25hp Tohatsu outboard bought new. Despite ALWAYS flushing out in fresh-water, the engine is getting hot, but no warning sirens or lights to indicate a fault and its only the tell-tale water temperature that indicates something is wrong. No 'limp mode', nothing. In fact the engine runs exceedingly well. When taken back to dealer, he confirmed thermostat working but replaced in case, impeller changed etc etc, but now he has said the pipes were completely blocked with salt. (yet water still running freely through them?). I can only assume that the engine is running so hot that when engine turned off the water evaporates so quickly that salt is left behind, although this should have cleared through flushing process. Has anyone else come across this problem?
