Bassmandan
Not sure if this Is the right forum. Let me know. Does Chrysler own Force brand now? I dont see Mercury Force listed. Anyway I have a 1992 40 HP Mercury Force. Engine 0E048891. Overheat buzzer will not shut off. Buzzer not shown in your manual to possibly order one. I have the one located inside of the control shift box. Engine overheated. Luckily the overheat buzzer came on and I turned it off and got a tow to shore. No water from pump. Replaced water pump and impeller drive pin. I now get a steady spurt of water but not a actual stream flow. Anyway overheat buzzer in control box will not go off. Just turning the key on without actually starting engine the buzzer sounds. Stays on when cold or warmed engine is started. I thought maybe to replace the buzzer in the control box, which is a nightmare to take apart and close back together. Cant find the right part number. Manual shows a different control box and a buzzer outside of box. Or is there a solution to this issue without replacing buzzer? Any help or thoughts would be appreciated.
