was wondering if anyone had any insight on a problem I have been having.
I have a 1986 looper VRO Johnson 120HP on my ol 'Ranger. Original motor. One day I had it out and fired it up (always starts right up) and was idling. Well, about every 30 seconds it "hiccups". Thats the only way I can describe it. It doesnt "stall" or anything, it sharply cuts off for half 1 second, then cuts right back on. It does this every 30 seconds. Its not sporadic, it is literally every 30 seconds or so like clockwork. I dont have to restart it, because it cuts right back on. Also, when it happens, during that 1 second that it cuts off, the Gas gauge also cuts off, then right back on. So it might be something electrical? Put in all new sparkplugs, new fuel filter, but didnt fix the issue. Then after about 20 minutes of that, it will stop hiccuping and run fine again.
Yesterday I had it running at my house with earmuffs on and it was doing it again. I turned the motor off to go get my phone (was going to get a video of it to post) But when i came back out and started it up, it didnt do it! lol. I let it run for like 10 minutes with the muffs on at idle, and nothing.
It happens no matter the speed, at idle, half throttle or WOT. I have one little depth finder directly connected to the starter battery (not connected through the dash interface) And it does not hiccup when the rest of the system does.
Thanks in advance for any info you can shed!
