LakeErieFishing
To drain the water entirely from the engine block and logs/risers, can I just remove the petcocks from the engine block or do I also have to detach the hoses for everything to drain?
On the S B Chevy engines, the drains alone will do it.
jeff
Not at conputer now but if needed i will respond in detail in the morning.
To add to what BT said.
You have a incoming water hose, it comes from the transom area on the drivers side of boat. It goes to the thermostat housing.
This is the incoming water supply to engine from outdrive.
Remove the hose from thermostat housing, fill hose with RV antifreeze until it leaks out of the outdrive which should be in the down position.
This back flushes the incoming water hose, Power steering cooler and makes sure no residual water is left in that part of the water system.
It takes time and you will have to add small amounts RV antifreeze at a time several times to get the pressure to push the water back out.
I would also remove all the small hoses at the thermostat and fill each with RV antifreeze to make sure it gets into every nook and cranny. Just a precaution.
As BT said, the very Large hose at from of motor that goes from motor mounted water pump to thermostat housing,
Remove from thermostat housing and bend down to dump any water in it, then after block plugs (both sides of engine near oil pan area approx center of block) have been removed, and all water has drained, put plugs back in and then fill RV antifreeze into large hose and this will fill block. Use about one gallon.
In total you should only need 2 gallons of RV antifreeze but it is cheap and use what you feel you need. It is just a bit of insurance if you missed any small amounts of water.
No need to read any article.
The advice given is proven by professionals.
Enough said.
My advise is to have a competent established Marine Mechanic winterize your boat for you. Best $200 Labor charge you will ever spend.
Enough said.
Yep, that's why I came here, to get professional advice.
I'll be getting back with you once a try a few more fixes prior to winterization.
$200.00
I must be doing it wrong...............all my friends get it done for BEER!!...But Beer is good!!
When it comes to business and marine repairs, I have no friends.....LOL
Chris, that is the difference between "Professional" and "Non-Professional".
People like you and I have earned an income doing Marine Repair.
I'm not sure that recieving beer for payment qualifies one as being a "Professional"!
Mr. LakeErieFishing, I do wish you the best of luck! None of us want to hear about a cracked cylinder block or exhaust component come next Spring time!
