MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 1 of 1
  1. #1
    Default Positive mixture experiment
    Hi there,
    I live in Greece and run currently a `86 50Hp Mercury behind my classic 13´ Hannibal Deep-V Racing Boat.
    Currently I am in the process to fit the old proper XS850.., but that is a different thread in the near future.
    For 2 seasons and many engine hours I ran the 50Hp motor now with synthetic 2-stroke oil from Bardahl only. The reasoning was that the oil these days is much more efficient , so I stuck to mixing the fuel 70-75:1 instead of the originally proposed 50:1 ratio.
    The motor has not lost any compression and I can not note any change in its running habits. Actually I have the impression that my procedure has cleaned out over time the exhaust and its entire system, so I have the feeling that the motor runs better then ever before!
    -The only backdraw..., now the exhaust joints, gaskets and seals appear to give up and let fumes out into the cowling together with cooling water...
    Is that now old age.. or a result of some ingredient of the synthetic oil?
    Has anybody indulged him-/herself in similar experiments?
    My `to-be-new´ XS850 is 10 years older still, may there be seals and flanges that might not agree with synthetic lubricants??
    I wish you all a great time on the water!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Last edited by Wotan; 09-14-2016 at 09:27 AM. Reason: Wrong picture attached accidentally
Similar Threads
  1. positive to negative ground
    By scouser4 in forum Boat Electrical Systems
    Last Post: 10-25-2012, 06:42 AM
  2. Prop Experiment SEEMS to go VERY WELL
    By knuckle47 in forum Crusader Marine Archive
    Last Post: 06-11-2009, 05:19 PM
  3. Positive or negative ground
    By badger5301 in forum Mercruiser Sterndrive Archive
    Last Post: 05-08-2009, 04:01 PM
  4. Power to positive bus
    By smitair17 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-21-2009, 07:18 PM
  5. Positive ground
    By jim81961 in forum OMC Sterndrive and Inboard Archive
    Last Post: 02-04-2009, 09:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
