Click forPleasurecraft Marine parts and manuals!
Results 1 to 6 of 6
  1. #1
    Default Base timing procedure
    Can someone tell me the procedure to set base timing on a 2001 Seamaxx 5.7 HO TBI?
    ive been searching for two days and can't find!
    thanks
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,884
    Default Re: Base timing procedure
    maybe....any idea which distributor is used? which ECU (MEFI-x)?
  3. #3
    Quote Originally Posted by makomark View Post
    Not exactly sure which distributer or ecu , but it is MEFI 3.
    appearently just need to jump A and B pin on data link connector.
    I adjusted the base timing from 9 BTDC to (spec) 10 BTDC. When come out of service mode the timing goes back to 9 BTDC. I. Thought timing at idle would be same as base but it isn't. I'm not sure if this normal or indicative of a problem or the result of the rich condition or fouled plugs.
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,884
    jumpering A & B gets you into service mode, whichs locks the timing and, depending upon the program flashed in, may raise the idle speed.
    when you exit service mode, the ECU resumes dynamic adjustments of the timing and all the other adjustments. you can find the Delphi MEFI-3 manual on the www with a bit of searching....it provides more detail than most people want.
    As far as "other issues", you can "read the codes" from the ECU while in service mode...if there are no codes saved, then the computer doesn't see any problems. the bad news is not everything needed is connected to the computer.
  5. #5
    Thanks! I recently got a MEFI-3 scanner and have been trying to find a book or manual that will explain how to interpret all the data, but have not been succesful.
    the cllosest thing I have found is: http://www.google.com/url?sa=t&rct=j...32479545,d.dmo
    But this pretty much just explains how stuf works, doesnt really o into how to disgnose or interpret the data.
  6. #6
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,884
    send me your email via the private message tool and I can help out there
Similar Threads
  1. Proper procedure for testing timer base on OMC looper v6
    By chessbass in forum Johnson Evinrude Outboard Forum
    Last Post: 06-24-2013, 01:03 PM
  2. Crusaer 454XL Timing Procedure
    By lgarofalo01 in forum Crusader Marine Engine Forum
    Last Post: 10-03-2011, 01:59 PM
  3. timing procedure for 1996 5.7 L
    By wake20 in forum Mercruiser Sterndrive Forum
    Last Post: 06-07-2011, 02:39 PM
  4. AQ131A timing procedure
    By film842 in forum Volvo Penta Gas Engine Forum
    Last Post: 05-15-2010, 01:06 PM
  5. Mercruiser timing procedure
    By nasty203 in forum Mercruiser Sterndrive Archive
    Last Post: 04-03-2009, 02:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
