Results 1 to 2 of 2
Thread: Reduction info
  1. #1
    Default Reduction info
    What's involved in changing the reduction gear on a 71 ? Would it be worth the effort to swap a 1 to 1 for a 1.53 to 1? They seem to be more readily available and cheaper. Thanks to all.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,258
    Default Re: Reduction info
    a reduction unit makes the whole assembly much longer....the 1:1 gears are usually installed on smaller light weight hulls...the reduction gears on bigger, heavier hulls....changing the gear ratio means getting a new prop (or repitching the old one - maybe)....
    finally, under normal circumstances, a gear that's just worn out can be overhauled very economically.....lots of unknowns buying a gear from 'john doe'...
Similar Threads
  1. Perkins 4-108 ID and Reduction size?
    By Dreadnaught in forum Perkins
    Last Post: 05-03-2014, 01:48 PM
  2. Honda 200 rpm reduction
    By hurricane in forum Honda Outboard Forum
    Last Post: 09-16-2009, 11:10 AM
  3. 225 alarm amp rpm reduction
    By fleter in forum Honda Outboard Archive
    Last Post: 01-21-2009, 07:08 AM
  4. REDUCTION RATIO
    By go_bucks in forum Crusader Marine Archive
    Last Post: 12-01-2006, 06:12 PM
  5. Reverse reduction gearboxes
    By fiori in forum Archive 2003-2007
    Last Post: 10-17-2002, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
