98SeaRay290
Hello,
I am hoping someone can help with a problem that I having. I have twin 4.3L Mercruiser's engines with Alpha One GEN two outdrives. Engines have double barrel carbs, thunderbolt ignition. My problem is that I have no power when both engines are at WOT. The boat stands straight up, barely moving and never planes out. Both RPM gauges are reading around 4000 at WOT. Both outdrives and trim tabs are fully down as well. I changed the fuel/water separator filters as well as checked the inlet filters going into the carbs but did not see any sediment restricting fuel. Also no water could be seen in the filters. I am hoping this has happened to someone and could get some advise before getting compressions taken and digging deep into the engines. Pretty sure the props are not slipping as my RMP's are not going past 4000. Growth on the hull shouldn't be an issue either as I use the boat a few times a week. Any help would be greatly appreciated!
Thank you,
CW
Thank you,
CW
