Results 1 to 2 of 2
    Default 1960 Tollycraft 215 HP ford interseptor engine cooling system
    I have a 1960 17' Tollycraft Sportabout with a Ford 215 HP interceptor inboard engine. I ran the engine with the boat out of the water supplying water to the water intake at boat bottom and did not get any water being exhausted while engine running. I turned off the engine to prevent overheating shortly. I am not that knowledgeable on the water cooling system. Does the inlet water circulate through the engine after engine warms up or should it be immediate and water exit through the exhaust ports? How can I troubleshoot further? What would be a source for parts if any is needed?
    Thank you,
    Kaz
    Sep 2008
    Maryland - USA
    6,878
    Default Re: 1960 Tollycraft 215 HP ford interseptor engine cooling system
    you should have cooling water supplied to the exhaust whenever the engine is running....how it gets there will be determined by the cooling system design used. There are two basic setups: raw water cooling and closed cooling (aka fresh water cooling). the latter has a heat exchanger which is typically filled with an antifreeze solution.
  1. Can you add engine ice to a closed loop cooling system
    By jadilla in forum Mercruiser Sterndrive Forum
    Last Post: 11-19-2014, 10:53 PM
  2. Cooling system for ford 50
    By westsider in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-10-2009, 02:44 PM
  3. Closed water cooling system verses a raw water cooling system
    By Dan Stephens in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 02-19-2008, 01:56 AM
  4. Engine cooling system open or closed type
    By taps in forum Mercruiser Sterndrive Archive
    Last Post: 12-21-2006, 04:39 PM
  5. Inboard engine cooling system
    By Stan Toy in forum Archive 2002-2006
    Last Post: 09-16-2001, 11:52 PM
