Page 2 of 2 FirstFirst 12
Results 31 to 37 of 37
  1. #31
    Default Re: What may have caused destruction of crankshaft
    Doh!!! Yeah it's kinda obvious, it's late and been a busy day. Should hopefully have the motor rebuilt and back in the boat by Sunday, picking new crank up on Friday.
  2. #32
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,743
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #33
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,968
    Chris,Not sure if you are aware but their talking about starting a newly rebuilt engine, I have used this method many times before breaking in a new motor
  4. #34
    What is the oil capacity of a 4.3 with aluminium pan AND remote filter setup, I want to make sure the dipstick tube is set at the correct position in the block, I have fitted an oil drain tube to the drain plug which is 45" long using 8mm ID hose. The book says 4.3lt capacity but that is without the remote setup
  5. #35
    The mechanic has the special tool to spin the pump, (not a converted distributor shaft) will this still send oil to the rockers
  6. #36
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,178
    if he has a priming tool, it will get oil everywhere it needs to....as far as capacity goes, it will vary due to the installation. Most OEM's provide a dipstick and will tell you as long as you fill the crankcase to the fill mark, per their procedure, you will be fine....if you read their fine print, all capacities listed will be denoted with the 'approximate' disclaimer...
  7. #37
    Thanks makomark, I've seen pics of the tool and it has a collar with a groove to send oil to the top, same as the dizi shaft, not sure if the mechanics is the same as I didn't see the collar, anyway I now know what's needed. As regards the oil capacity, unfortunately the dipstick tube is loose in the block and can be positioned incorrectly so the mark on the gauge would also be incorrect, I am assuming however that the tube would almost touch the bottom of the pan (for sucking the oil out) so I will try and position it there, I have fitted a drain tube from the sump plug that exits through the transom drain plug to make oil change easier.
Similar Threads
  1. in need of a crankshaft rebuilder (4 stroke) or second hand crankshaft
    By gazza2011au in forum Mercury Mariner Outboard Forum
    Last Post: 02-17-2013, 02:30 PM
  2. Honda BF225A engine destruction
    By mechman28 in forum Honda Outboard Archive
    Last Post: 08-23-2008, 03:48 PM
  3. Damage caused by overheating
    By adam_g in forum Mercruiser Sterndrive Archive
    Last Post: 06-29-2007, 10:31 PM
  4. Volvo aq130 with 275bs destruction
    By ac680 in forum Volvo Penta Gas Archive
    Last Post: 09-24-2006, 12:01 AM
  5. What might of caused this
    By dave in forum Outboard motors archive 2000-2004
    Last Post: 05-18-2002, 05:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
