Have a pair of 1979 Mercruiser 228 GM 305's . Very randomly the Port motor will suck lake water into the motor when shut down. This causes the motor to hydro lock. I then have to pull the plugs and blow the water out. This motor has a split sea water cooling system . Coolant in the engine and sea water through a heat exchanger . The Starboard motor never does this and as I said it happens instantly and randomly . May be every twenty start and stop cycles. The fluid in the cylinders does not have any coolant in it. Any Ideas what can couse this?
