BRBHorizon
Took it out last night with the auxiliary tank [note to self, don't go too far, almost ran out ]
Seemed to run a little better. Idle was faster for sure but still rough. Stopped long enough to cool engine... Attempted restarted with no pump of primer and no throttle and all was good. That's a first. So I think part of my issue is the fuel delivery. I have everything on order to replace from the tank to the motor.
Now... The other issue(s) it still runs very rough at idle and the most I got was 4300 RPM. I know the tach is accurate because I tested it with a hand held tachometer and it was pretty much bang on.
Would the de-carb help? Should I have the carbs cleaned? I suspect this boat/engine sat for a loooooonnng time without running.
