Results 1 to 2 of 2
  1. #1
    Default 1991 4.3 mercruiser engine exhaust manifolds
    Thinking I drained all the water out of the system it appears not so, draine the block , and took off some hoses, did not drain the
    exhaust manifolds,thinking gravity would do the rest.
    After sitting for a year and thru winter , went to start up and was hard startingag poured some gas down the carb and went
    for a few seconds.
    Did this a few times till I noticed water under the manifolds going into bilge , took off the port side and discovered the crack,
    would this cause the stalling?
    Heard about welding but think its not worth it , just get replacements. Cracks are on engine side by serial #.
    see pics attached
    Searay 91
    Sorry have to figure outhow to post pics.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,883
    Default Re: 1991 4.3 mercruiser engine exhaust manifolds
    A busted exhaust manifold could contribute to your symptoms if the leak makes it to the spark plug wires (shorting them out)....otherwise no.
    I'd be inclined to check the oil (make sure its water free) before buying anything.....would be best to test the block to make sure it isn't cracked (but much more effort required there)...
    If there's any age to the manifolds (or significant corrosion), welding usually doesn't yield a long term solution...
Similar Threads
  1. 1979 Mercruiser exhaust manifolds.
    By Gemini_Sosa in forum Mercruiser Sterndrive Forum
    Last Post: 08-20-2013, 01:28 PM
  2. Wanted: Ford 351 W Log Style Exhaust Manifolds and Engine Backing Plate
    By Lukes Projects in forum Volvo Penta Gas Engine Forum
    Last Post: 10-18-2011, 09:58 AM
  3. 1981 260 mercruiser exhaust manifolds advice and opinions
    By kfx400 in forum Mercruiser Sterndrive Forum
    Last Post: 06-03-2011, 01:06 AM
  4. Recommendations to replace Exhaust Manifolds amp Elbows 50 Mercruiser
    By bayray in forum Mercruiser Sterndrive Archive
    Last Post: 04-06-2009, 11:44 AM
  5. Replace OMC 43 exhaust manifolds with Volvo 43 manifolds
    By chris_f in forum OMC Sterndrive and Inboard Archive
    Last Post: 02-27-2007, 12:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
