Results 1 to 13 of 13
  1. #1
    Post How to repair the remote for Haswing Cayman trolling motor
    If the remote doesn't work well ,pls check if below option can help you or not .
    1.1.if the right is not flesh ,it may be low power ,pls charge .
    2.if the remote can't contact the motor , pls press the SYSTEM REBOOT KEY ,then try contact again
    If you are interested in Haswing Cayman trolling motor ,pls contact me :
    [email protected] Or find "Haswing Cayman trolling motor" on Amazon / Ebay. Thank you .
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,908
    Default Re: How to repair the remote for Haswing Cayman trolling motor
    This a repair forum not an advertising network!
  3. #3
    Sorry , Pls contact me if someone have problems about Haswing trolling motor .
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,644
    Kinna funny tho he will tell you how to fix the motor before you buy it.
  5. #5
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,908
    I glad somebody made sense of that!
  6. #6
    Haha ~~ all right . actually ,I come here to learn more information about electric trolling motors , I start sell trolling motor just several weeks ,know little about it . My friend Jon said I will learn more in this Forum ,So I come ,but don't know how to say hello ~~In short, sorry for the bother . Now would some one can tell me how to change the user name "Haswing', My name is Sunny ,I want use my own name "Sunny" ,thanks
  7. #7
    I have owned a Haswing Cayman for less than a year now. The remote quit working so I took it apart to change the battery. What a surprise to find that the battery was not exchangeable. It had a foil encased battery pack. I have tried to contact Haswing several times and had not response at all. I am very disappointed with this companies customer support. I now have a trolling motor with no remote.
  8. #8
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,908
    mtn.boy,maybe that"s how they stay in business, Send a picture if you can, find out the voltage of that battery,maybe a wiring harness can be soldered in to accept a rechargeable battery
  9. #9
    Quote Originally Posted by johnnygjr View Post
    thanks johnnygjr! That's a good idea. I have a friend that owns an electronic store. I think I will go and see if he can help me out. Again, Thanks!
  10. #10
    Thanks for sharing this idea.
  11. #11
    Thanks for sharing this helpful idea.
  12. #12
    I really like this post..
    Power Transformers in India | Wire Harness Manufacturer in India | Transformer Manufacturer in India
  13. #13
    The new Haswing remote for the Cayman 55 lb or 80 lb trolling motor is rechargeable via a USB cable. The older style remote has a CR2032 3 volt battery. This battery has a short lifespan, so I recommend that you keep a spare with your boat and a small phillips head screw driver to open the back of the remote allowing you to replace the battery. Be very careful when you put in a new battery. There are prongs designed to slide on top of the positive side and a separate set of prongs under the negative side. If you don't examine it carefully it can appear that both sets of prongs go under the battery. I did this and caused the remote to stop working. I was ready to throw the remote away until I discovered my mistake.
Similar Threads
  1. evinrude scout trolling motor repair
    By [email protected] in forum Other Trolling Motors
    Last Post: 05-01-2017, 11:32 AM
  2. Sealing connection between motor head and shaft (electric trolling motor)
    By hmoto in forum MotorGuide Trolling Motors Forum
    Last Post: 06-22-2014, 09:17 AM
  3. remote control transom trolling motor
    By modelt in forum Other Trolling Motors
    Last Post: 10-12-2013, 06:34 PM
  4. Repair to Minn Kota Weedless 65 Trolling Motor
    By johnworks3 in forum Minn Kota Trolling Motors Forum
    Last Post: 07-04-2012, 02:57 PM
  5. Motor Guide Brute 750 Trolling Motor Parts
    By Donewright in forum MotorGuide Trolling Motors Forum
    Last Post: 04-09-2012, 06:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
