Results 1 to 4 of 4
  1. #1
    Default Navigator trolling motor setup
    i have a dual electric motor setup, Marinetech
    a total of 110 # thrust
    both motors are wired to one remote control ..
    only 1 motor turns
    any suggestions ?
    thanks ......
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    3,015
    Default Re: Navigator trolling motor setup
    On motor that does not run on remote,hot wire it,jumper cables from battery + to motor+ And ground from batt, to ground on engine
  3. #3
    i hotwired the motor to the battery and it turned.
    on my navigator dual motor setup, there are external fuse blocks on each wire connection to the battery.
    anyone familiar with this type of fuse ?
    the bottom portion of this block appears to be a sealed unit.
  4. #4
    Quote Originally Posted by modelt View Post
    THIS FUSE IS MANUFACTURED BY " COOPER BUSSMAN, called a SHORTSTOP
    its suppose to be re set able, anyone know how to do this ?
    thanks
Similar Threads
  1. Sealing connection between motor head and shaft (electric trolling motor)
    By hmoto in forum MotorGuide Trolling Motors Forum
    Last Post: 06-22-2014, 09:17 AM
  2. Motor Guide Brute 750 Trolling Motor Parts
    By Donewright in forum MotorGuide Trolling Motors Forum
    Last Post: 04-09-2012, 06:16 AM
  3. Trolling motor
    By samaros in forum Johnson Evinrude Outboard Archive
    Last Post: 03-01-2008, 05:06 PM
  4. CORSAIR NAVIGATOR 10 HP PLEASE HELP
    By gephart_small_engine in forum Archive 2003-2009
    Last Post: 01-27-2006, 10:00 PM
  5. Trolling motor
    By buddy in forum Archive 2003-2009
    Last Post: 09-15-2003, 04:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
