I recently bought a small boat with a 92 Johnson 60 on it. When i bought it we ran it on mufs and it sounded fine. I got it home i ran it again on mufs but the thing would not run... I found that the only way i could get it to run was if i turned the fuel valve (service port) on the top of the primer pump to just barely on it would idle fine. I found a crack in the cover of the primer pump the ball was leaking i also changed the fuel pump and fuel filter for good measure (not the stock pump it was converted to non VRO at some point). I have also changed all fuel lines and cleaned the carbs but im running out of ideas i have replaced almost the entire fuel system and still no luck. I have good compression and new plugs in all cylinders as well what am i missing.
