SuperT
I was looking at the breakdown of the lower unit when I discovered something that has me perplexed. When changing/replacing the prop it lists prop hub, cotter pin, drive pin and thrust washer!!
I purchased my motor used a bunch of years ago and have had the prop off several times over the years.Ive never seen a thrust washer or knew there was suppose to be one.
From the diagram it shows it between the drive pin and the prop hub. To me it don't make sense, because the prop is pinned to the drive shaft already (in the front) and can't move front or back. Can someone explain just what it's purpose is?
It's ran fine all these years without it, but I've ordered one anyway.
