Results 1 to 11 of 11
  1. #1
    Join Date
    Aug 2016
    Location
    Stokes Bay, Ontario, Canada
    Posts
    6
    Default 1.6 Litre OMC Sea Drive Identification
    Greetings everyone, from a new member!
    I have recently purchased a 22' Sylvan with a 110 HP, 1.6 Litre OMC Sea Drive.
    I understand they aren't particually well liked!
    This one has been sitting for an unkown time period, (5 or so years, I have been told by one source)
    There are many issues as you would expect!
    I would like to get a model year so I can purchase a manual.
    The numbers under the engine hood state: Model # 983775 Serial # 366956.
    Would anyone be able to help with the year?
    Thank you in advance!
    Regards
    Brian
  2. #2
    Join Date
    Aug 2016
    Location
    Posts
    6
    Default Re: 1.6 Litre OMC Sea Drive Identification
    The boat was built June/1986, so I'm thinking it should be about an 86 model, but would like it verified!
    Brian
  3. #3
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,935
    Likely it is a 1986 model.----Have a couple of seadrive V-4 motors for rebuild / parts and I am about 1-1/2 hrs away.----Please recheck those 2 numbers as they do not appear to be model numbers or even a serial number.
  4. #4
    Join Date
    Aug 2016
    Location
    Posts
    6
    Hi racerone
    I just braved to rain to double check those numbers on the mid section!
    It is possible there is an I or J (it is so lightly marked) at the start of the serial number, but other than that it is correct.
    I may need some parts, where are you located in Ontario? I am guessing the Georgian Bay area.
    Regards
    Brian
    I can send a picture of the plate if you provide an address!
  5. #5
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,935
    I am about 1-1/2 hrs south of you.------------The numbers you posted do NOT represent a model # or a serial # at all.
  6. #6
    Join Date
    Aug 2016
    Location
    Posts
    6
    Thank you for trying o help me!
    Those are the numbers from both plates mounted on the engine!
    One is on the port side of the mid section, another plate inside the engine cowling on the port side. Where else can I look for numbers?
    Are you near Durham or Hanover? Or are you down near Kitchener?
    I can call you to try sorting this out!
    Let me know how we can contact as I really need this running!
  7. #7
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,935
    Just north of Pt Clark..----------PM me.
  8. #8
    Join Date
    Aug 2016
    Location
    Posts
    6
    Ok, so I think I finally found the right plate! Located inside starboard side bottom engine cowelling!
    Model # 2BBXCOM
    Serial # J860332
    What year does this make my motor? (assuming these is the right numbers)
    Why would they put different model and serial numbers on the same drive assembly???????
    Thanks again!
    Brian
  9. #9
    Join Date
    Dec 2009
    Location
    Pickering and Lakefield, Ontario, Canada
    Posts
    748
    That model number makes it a 1985
  10. #10
    Join Date
    Aug 2016
    Location
    Posts
    6
    Thank you!
    I have the motor running great now, and the tilt and trim only needed a new fuse!
    i really appreciate the help!
    Regards
    Brian
  11. #11
    Quote Originally Posted by durhambrian3743 View Post
    Thank you!
    Regards
    Brian
    Would anyone be able to help with the year and horsepower?
    omc seadrive 1,6L # 2BBXCOM # J0860691
    bestregards arne
Similar Threads
  1. b88 OMC 1.8 litre OB w Sea Drive and 115 / 150 HP Johnson OB
    By outdoorshomeboy in forum Johnson Evinrude Outboard Forum
    Last Post: 03-18-2010, 12:14 AM
  2. OMC 18 Litre V4 w Sea Drive b88 b90
    By outdoorshomeboy in forum OMC Sterndrive and Inboard Forum
    Last Post: 03-09-2010, 10:16 AM
  3. 23 litre cobra stern drive
    By joesap in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-27-2009, 08:41 AM
  4. 1994 OMC 5 litre SX drive cooling problem
    By kawjetski in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-31-2007, 05:55 PM
  5. 1989 GM 57 litre 350omc drive
    By Joey Emberley in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-09-2003, 10:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
