[h=1]So I decided to replace the impeller on my 1969 6hp and when I pulled the lower unit off, I went to remove the pin at the top of the drive shaft and it came out in 3 pieces. I've seen on this board that some folks replaced it with something else but suggest use semi soft metal. Is there something that you can replace this with that will work well or should I just purchase a new one ?
I found the following OMC part number 0303261 but I'm in Canada so it would be more than a week to get it. If something else can do the same job and I'm not compromising the motor, please let me know otherwise I'll order one up.[/h]Thanks
