Results 1 to 4 of 4
  1. #1
    Default Lower Carter side draft carb flooding
    Sorry if this issue is on the forum somewhere I could not find it.
    I have a 1963 Tollycraft with a Ford Interceptor 292 with side draft Carter carbs. I had the carbs completely rebuilt 5 years ago and they have worked fine until now. Here's the problem now:after running the boat for a while when I slow to idle my lower carb floods (sometimes enough to kill the engine). Once the engine has died due to flooding or I have turned it off the lower carb drains out fuel...a lot of fuel. I assume this is related to the float/needle valve/seat. I have inspected these parts in both carbs and have nothing incriminating so far. Could it be that due to the alcohol in the fuel these days that I just need to replace the needle valve/seat again? Any help would be appreciated, thanks!
    Dave
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,726
    Default Re: Lower Carter side draft carb flooding
    I think you hit the nail on the head,The ethanol could be eating up the rubber seal on the needle valve, Check for debris in seat,does not take much. Check float level carefully, Is float binding on bowl? Is float floating? Binding mechanism on hinge side?
  3. #3
    Quote Originally Posted by johnnygjr View Post
    Thanks johnny. I have inspected the seat, needle valve, float, etc and NOTHING stands out to me. But maybe the rubber tip on the needle valve is just warn from the stupid fuel I have to use that it is not seating right. Thanks for the ideas on the float...I'll look at it again.
  4. #4
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,726
    Keep us posted 63Tollycraft.
Similar Threads
  1. side draft carter yh to down draft conversion
    By jeff163 in forum Ford Interceptor Marine Engine Forum
    Last Post: 07-10-2010, 01:12 AM
  2. Side draft carbs
    By paycojoe in forum Gray Marine Gas Engine Forum
    Last Post: 12-23-2009, 01:55 PM
  3. Solex side draft to down draft conversion
    By ejbtech1 in forum Volvo Penta Gas Archive
    Last Post: 02-17-2008, 11:18 AM
  4. Aq120b Solex 44 phn2 side draft carb
    By bestbowl in forum Volvo Penta Gas Archive
    Last Post: 08-21-2007, 06:33 PM
  5. SOLEX SIDE DRAFT CARBS
    By cbdinak in forum Volvo Penta Gas Archive
    Last Post: 08-08-2007, 12:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
