Results 1 to 1 of 1
  1. #1
    Default Volvo Penta Archimedes 39 (3.9Hp)
    Hey!
    Was going to start fishing and took out my old outboard boat engine Volvo Penta
    Archimedes 3.9Hp, also available from Monarch o Crescent.
    Press Link:
    http://forum.hamnen.se/filedata/fetch?photoid=285183
    But that's the way it has been in at least 15 years in the storeroom, had intended to do a service to it,
    Finds no service manual here on the internet so I wonder if there is someone knowledgeable on this engine and
    has served it, find some info but wonder about the following.
    If the shaft from the engine down to the propeller should have no oil, axle goes through the bronze-bearing so you think it should be oil there too so that the propeller gear.
    Have seen that it is one / two screws in the middle of the rig, they can be of the oil on the filling of the shafte?
    If anyone has a service manual overhead that would be interesting!
    http://forum.hamnen.se/filedata/fetch?photoid=285184
    Or this
    http://forum.hamnen.se/filedata/fetch?photoid=285185
    Word list:
    Skruv = Screw
    Olja = Oil
    Vatten = Water
    Avgaser = Exhaust gases
    Lager bussning = bearing Bush
    Axel = shaft
    Diameter = diameter
    Kugghjul = Gear
    Packbox = Packing(ring)
    Axellager = shaft bearing
    Skruvar är dom för olje på fyllning? = Screws are they for oil in the filling?
    All the information on this engine is interesting as switches, copy of service bok etc.
    Have a nice day!
Similar Threads
  1. archimedes/penta 450
    By slider1525 in forum Gale Outboards
    Last Post: 08-10-2010, 01:05 PM
  2. volvo penta archimedes 70 hp
    By [email protected] in forum Volvo Penta Gas Engine Forum
    Last Post: 08-05-2010, 12:20 AM
  3. Archimedes Penta 360
    By dasboot in forum Other Outboard Motors
    Last Post: 06-14-2009, 11:27 AM
  4. Volvo Archimedes Penta 360
    By dasboot in forum Yamaha Outboard Archive
    Last Post: 06-13-2009, 11:54 AM
  5. Archimedes penta 120
    By oase44 in forum Archive 2003-2009
    Last Post: 07-01-2007, 02:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
