actualley I did attempt to seal the pod I 5200ed pieces of aluminum
to all the extra engine holes and the 1/2" drain also sealed all around outside to transome water still seaped in probablley though where the lid bolts to the top of pod. so I had to remove 1/2" drain didn't want water trapped in there and rot pod from inside out.remember this is mainly a saltwater vessel.
I think the water was getting in at launch ramp where the center of gravity was negative (vessel's bow tilted up forcing stern much lower) the lid was about 4inches from water surface so it must be splashing in though bottom of lid.
the laundry detergent bottles have taken up space where water would normalley be proballey about 80% and has helped vessels WOT stability.
my next attempt to increase this 80% to further reduce water in the pod will be a a inflatable ball used as a bladder or smaller (better positioned) detergent bottles if I can get bottles to fit and fill the pod then maybe poured in foam inside bottles would be better than air and provide some floatation.
the vessels stern drive had a large diameter/ w/a low pitch prop not sure of exact size I think because of vessels shape.
how much speed will I lose w/ a 17 pitch prop? or will I gain RPM thus gain speed?
will a 15.25 diameter be to wide?
Thanks TB
Thanks TB
