Hi, I have a 2005 crusader 8.2l 502xli. After 15 min of running perfectly at 3400rpm, it suddenly dies. No sputter, just like flipping a switch. It will start again after a min or two but the starter motor really struggles to turn the motor, acting like it is almost locked up. When it does start to turn it fired right back up but will die again if I take it above 3000 rpm. It will run fine for hours when below 2500rpm.
I have replaced the fuel filter, fuel pump, coil and wires and plugs. Gas in tank is about 12 months old but was stabilized. Starboard motor is on a separate tank and had the same age gas and runs perfectly. I have also checked for fuel leaks and have ran the boat with the fuel cap off...still having same issue. I've also swapped the ecms from starboard to port and no difference.
Any ideas? Could it be water in fuel? Or perhaps the ignition module or rotor/cap/distributor? Thanks so much in advance for any direction.
