Click forPleasurecraft Marine parts and manuals!
Results 1 to 4 of 4
    Default Pcm stern drive help!!!
    I have a 1987 sunliner with the pcm 302 and pcm stern drive im trying to replace the water pump impeller and can't seem to remove the lower unit I have all the bolts removed is there a bolt I'm missing or a truck to removing it on the boat
    Apr 2016
    barnegat NJ
    2,726
    Default Re: Pcm stern drive help!!!
    Remove trim tab on lower unit, might be a bolt under it.
    Turns out there is no impeller in the foot only on the front of the motor
  1. Carburetor Parts for 1988 OMC Stern Drive 2.3L 232AMRGDP Stern Drive
    By outdoorperson in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-27-2016, 01:01 PM
  2. Yamaha YAMS stern drive / Alpha type drive - reverse/shift cut out adjustments
    By HiZ in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 06-13-2013, 09:24 AM
  3. Omc stern drive please help
    By freddiedad in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-23-2010, 12:52 AM
  4. 1986 OMC Stern Drive Stringer Mount Stern Drive I Believe
    By yukon in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-16-2009, 09:52 AM
  5. Replies: 5
    Last Post: 05-27-2007, 08:21 PM
