Click forPleasurecraft Marine parts and manuals!
Results 1 to 4 of 4
  1. #1
    Default Pcm stern drive help!!!
    I have a 1987 sunliner with the pcm 302 and pcm stern drive im trying to replace the water pump impeller and can't seem to remove the lower unit I have all the bolts removed is there a bolt I'm missing or a truck to removing it on the boat
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,908
    Default Re: Pcm stern drive help!!!
    Remove trim tab on lower unit, might be a bolt under it.
  3. #3
    Turns out there is no impeller in the foot only on the front of the motor
  4. #4
Similar Threads
  1. Carburetor Parts for 1988 OMC Stern Drive 2.3L 232AMRGDP Stern Drive
    By outdoorperson in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-27-2016, 12:01 PM
  2. Yamaha YAMS stern drive / Alpha type drive - reverse/shift cut out adjustments
    By HiZ in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 06-13-2013, 08:24 AM
  3. Omc stern drive please help
    By freddiedad in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-22-2010, 11:52 PM
  4. 1986 OMC Stern Drive Stringer Mount Stern Drive I Believe
    By yukon in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-16-2009, 08:52 AM
  5. Replies: 5
    Last Post: 05-27-2007, 07:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
