Results 1 to 2 of 2
  1. #1
    Default 1969 Correctcraft mustang with very sluggish Ford 302
    Not being a mechanic, there may be a few stupid questions...Have Ford 302 in a 1969 correctcraft mustang...Experiencing no hole shot at all any more..There is no acceleration..It has been dificult to start, although usually does...Appears to be running rough but will idle...recently replaced plugs, wires, dist cap, rotor, points. coil and external resister..Haven't touched the fuel pump or the carb for the 11 years I have owned it..I have had two people who I trust mechanically tell me to pull the carb off and either rebuild or replace..(Holley 4 brl)...and really don't have a clew when it comes to proper timing adjustments, carb adjustments, etc..I can gradually get this boat up to 40mph but and it barely pulled my daughter out of the water on a wakeboard at 100lbs..Just was looking for ideas about where to starting looking for the cause of the problem..Will appreciate any feedback!
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,996
    Default Re: 1969 Correctcraft mustang with very sluggish Ford 302
    Start with a compression test,might find video on utube.then check for spark on all cylinders,then troubleshoot fuel system.the engine is 47 years old!! Start there and post results. We will get back to you.
Similar Threads
  1. 1969 Ford 302 Interceptor Plug Wire Location
    By SWEETWATER69 in forum Ford Interceptor Marine Engine Forum
    Last Post: 07-29-2015, 08:18 AM
  2. 2.3L OMC Cobra = 2.3L Ford Mustang
    By chef92 in forum OMC Sterndrive and Inboard Forum
    Last Post: 03-30-2015, 01:54 PM
  3. 1969 429 ford engines out of a chris craft are they worth anything?
    By Adam Clark in forum Ford Interceptor Marine Engine Forum
    Last Post: 08-09-2012, 05:14 PM
  4. Identification question 1969 crusader300 Ford Cobra
    By Scott Tyner in forum Crusader Marine Archive
    Last Post: 03-06-2006, 09:03 PM
  5. 1969 Correctcraft wildcat steering
    By Don Gunnon in forum Archive 2003-2007
    Last Post: 06-10-2002, 11:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
