Results 1 to 2 of 2
  1. #1
    Default 70el78c water pump
    We had the fins on the motor to run it while working on it. All of a sudden the water stopped coming out the end hole
    Could this be a clog and what should I do. We did order a new water pump kit and the motor has been sitting and taken apart. but before we put it back together is there any thing someone would recommend.
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,726
    Default Re: 70el78c water pump
    Sounds like water pump impeller failed, Use a good sealer with new gaskets&o-rings. Make sure surfaces are prepped properly. Some grease on upper spline of driveshaft. Make sure shift mechanism works smoothly before assembly.An assistant comes in handy
Similar Threads
  1. 10 hp sportwin with new water pump wont pump water to head
    By 85stang in forum Johnson Evinrude Outboard Forum
    Last Post: 07-02-2012, 12:14 AM
  2. 1992 Suzuki 225 water pump doesnbt pump water
    By rainey230 in forum Suzuki Outboard Archive
    Last Post: 07-15-2008, 06:59 PM
  3. 1978 JOHNSON MOD# 70EL78C
    By JACK M in forum Johnson Evinrude Outboard Archive
    Last Post: 06-13-2008, 02:26 PM
  4. AQ125B Water Pump Water circulation pump
    By scottk in forum Volvo Penta Gas Archive
    Last Post: 05-08-2008, 02:43 AM
  5. 70el78c
    By nx_brad in forum Johnson Evinrude Outboard Archive
    Last Post: 01-23-2007, 11:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
