I can apply throttle just fine at low speed, but when I push it down even further, the engine sounds and feels really rumbly/shaky and the boat will not go any faster. If I press the button in on the throttle so that outdrive is not engaged, the engine sounds fine even if I rev the engine really high.
All fluids are ok.
Other notable behaviors:
- Throttle lever seems to get stuck sometimes like the cabling has been stretched. For instance, sometimes hard to get it into neutral
- When I checked the oil, it is overfilled as it reads really high on the dip stick.
- When I turned the ignition off after the rumbly/shaky behavior, I heard a sputtering sound, almost like a muffled backfire.
Mercruiser (small v8), 150 hours
All fluids are ok.
