Hello all,
A few weeks ago, I posted a thread about some intermittent power problems I was having. After some troubleshooting and jumping to the conclusion that it was my kill switch, the problem is not resolved.
Here is the problem:
1. After turning the key, engine / controls lose power (rapid beep, no crank, tilt doesn't work)
2. Jumping does nothing, had to manually tilt
3. After driving home, tilt works, turning key gets ready beep but when key is turned, back to 1
(Battery voltage is good, terminal connections clean)
This makes me really suspect the ignition switch but I'd like to test before replacing. The engine is a 2010 BF60.
Can anyone recommend a test procedure? Or is this obviously the switch?
Thank you!
Thank you!
