Greetings my very helpful friends. Does this water pump base assembly need to be replaced when I do my water pump service? Or will I be OK with just the impeller, impeller base plate and gaskets. Keeping in mind that the housing is in good condition. It's a 2008 60hp two-stroke.
Rather not replace this part if I didn't have to. motors has had little use, i'm also reading that there a bitch to get out.
thanks!
thanks!
