Results 1 to 9 of 9
  1. #1
    Join Date
    Jul 2016
    Location
    Northern VA
    Posts
    6
    Default New motor- Just want to make sure its propped good...
    I just got a brandy new 2016 Evinrude Etec. i want to make sure its propped right-
    Its on a 1985 Starcraft SF 16'- rated for 40.
    boat- 550 including fuel. Gear/ People 550.
    I have a 10.3x12 prop on her. The anti-vent plate was too low (fixing it now)- it was too hard to steer and was measured 1/2 inch under keep. going for even to 1/8 in above the bottom. I figure its propped pretty well, at most go for a 10 1/8x 13.
    Am i on point? if so please lemme know!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	13684   Click image for larger version.
Name:	Evinrude Motor Only.jpg
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,660
    Default Re: New motor- Just want to make sure its propped good...
    Once you get it trimmed properly and distribute the weight accordingly use WOT rpms to determine if you need to change prop pitch. The big danger with a riveted aluminum boat is getting airborn. Make sure enough weight is up front to keep it on the water.
  3. #3
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,706
    WOT means wide open throttle,top rpms of your engine...
  4. #4
    Join Date
    Jul 2016
    Location
    Northern VA
    Posts
    6
    Quote Originally Posted by kimcrwbr1 View Post
    I worked the trimming the other day. #3 hole with someone and for best top speed alone, and #2 for windy/ medium chop. #4 hole id a no go It stood up pretty well, and I am sure #5 hole will get it vertical....
    It did 27.5 on #2 hole, 30.1 on on the #3 hole and porpoised with more trim.
  5. #5
    Join Date
    Jul 2016
    Location
    Northern VA
    Posts
    6
    Quote Originally Posted by johnnygjr View Post
    I know what WOT means. Im not new to engines- Hell, I built a 427 small block that does 10's all day w/ a 2 speed powerglide ect. No NOS or power adders. Just Bow Tie Perfection.
  6. #6
    Quote Originally Posted by MJ Cummings View Post
    Where did you get a 427 small block. You are missing a key piece of information what are your rpms. You want to prop your motor for the upper range of your WOT range with a light load.
  7. #7
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,706
    flying scott, Maybe we will get a response in a month or two about another 427smallblock that does 9's,I have a feeling there is no tachometer on his setup
  8. #8
    Join Date
    May 2011
    Location
    slough ,berkshire uk
    Posts
    161
    427 small block, sounds like a real good mechanic..
  9. #9
    Quote Originally Posted by phillnjack View Post
    There is a 427 small block it was put in the corvette somewhere around late 90s into the 2000s the LS7. This post is almost a year old.
Similar Threads
  1. Replies: 14
    Last Post: 05-14-2015, 08:59 PM
  2. what make and year motor
    By sticky in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 04-02-2010, 10:25 AM
  3. Can These E235s Make One Good One
    By bonden in forum Johnson Evinrude Outboard Archive
    Last Post: 08-21-2009, 11:09 PM
  4. What make is my b50 Electric SSb motor
    By lionstones in forum Other Outboard Motors
    Last Post: 03-29-2009, 10:39 PM
  5. What year and make is this motor
    By jim russell in forum Chrysler Force Outboard Archive
    Last Post: 04-18-2006, 01:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
