1957 Johnson 18hp
Ghg
Hi, having problem with my 1957 Johnson 18hp. I changed the impeller and now it won't go into forward gear. I carefully hooked everything back up after I removed the lower unit. The shift rod coupling is also connected properly. Thanks for your help.
