MissMaggi May
Thank you in advance for any insight on this topic. I did a battery test with an AVR tester. During the test it asks for a RPM increase to 1500 to test the charging system. The test result on this showed 12.7 volts. I use this tester on a daily basis but with automobiles and I know that with automobile motor the test should be somewhere between 13.2 - 14.6 volts showing a good alternator. This is my first boat and I know sweet nothing about the motor. What should be the charging volts from the motor to the battery. 1. At idle? 2. At full speed?
Just a note: I have been having to boost the battery after a few days to start the engine. I drove at a low idle for about 15-20 minutes. Shut down the motor and 1/2 hour later had to boost the battery to restart. After restarting engine I drove for 15 minutes at 3/4 to full throttle, shut the engine down and was able to restart the motor. Next morning had to boost again. I am almost 100% sure that my battery is pooched but do need clarification on charging output. Thank you.
