Hockeyguyjohn
Hi,
I just purchased a couple of mid 1980's B100S motors, I posted some photos here. http://www.marineengine.com/boat-fo...da-Value-(looking-to-buy)&p=543841#post543841
I took the lower unit off the one motor last night. Found the impeller housing damaged near the water tube and the cover is broken.
On the water pump shaft my Honda repair manual shows a "needle bearing below the ball bearing. Is there a needle bearing there?
On the shift rod there is seal holder, is this supposed to slide on the shift rod? I assume it is supposed to but this one is stuck.
I want to remove the extension case to change the seal on the water tube. I read my manual but it is vague on how the extension case is removed. Do I just remove the swivel bracket and the 4 screws holding the extension case?
Sorry for all the rookie questions, learning as I go along here!!
Thank you
John
Thank you
John
