gubernaculum
I have reduced every 2x4 block I had on hand to splinters with my 5lb hand sledge, so I am here for help if anybody has been through this:
The swivel tube on my 40hp mercury 4stroke efi corroded away, and finally failed catastrophically with a minor grounding at planing speed on a sandbar. It snapped - you can see where in the photo below.
I removed the lower unit.
Removed the power head.
Removed the upper motor mounts once the power head was off, and then was able to remove the adapter plate and driveshaft housing, exposing the top of the swivel tube. (See pics).
From there, I just can't beat the swivel tube out of the steering arm in order to replace the swivel tube.
The swivel tube has male splines, going up into the female splines of the steering arm. The swivel tube is supposed to drop out from the bottom. I beat on it with a socket, and was able to budge it down a bit, but no farther.
Since the swivel tube is broken in half, I tried to beat the whole swivel tube + steering arm up and out. No luck there either.
above: schemaitics
above: broken part
above: can't pound it down, can't pound it up. I was able to pound the whole assembly up about 5mm. I was able to pound the splined end of the swivel tube down about 1mm inside the steering arm, but no farther.
WHAT AM I MISSING HERE?
above: schemaitics
above: broken part
