Results 1 to 2 of 2
    Default Yanmar with visible corrosion - problematic or no issue?
    Hi All,
    I am looking to buy a boat with a 9hp Yanmar inboard engine - but when I looked at the
    engine there was quite a bit of corrosion on certain engine parts. The engine is 15 years old
    or so and had regular service according to the owner. Wanted to ask you whether you all
    believe that this is fine and nothing to worry about - or is this not looking good to you?
    Thanks!
    May 2015
    Oregon
    73
    Default Re: Yanmar with visible corrosion - problematic or no issue?
    Rust or some corrosion is on most marine engines that haven't been recently painted. Many engines have uses in auto or industrial and get a primer and paint job for non marine use.
  1. Corrosion on Yanmar 9hp inboard engine - normal or worrying?
    By panna in forum Miscellaneous marine engine topics
    Last Post: 07-01-2016, 06:52 AM
  2. Yanmar 3GM30F issue
    By OuterBanksSailor in forum Yanmar
    Last Post: 02-21-2014, 12:22 PM
  3. Yanmar 6LY sync issue
    By iansale in forum Yanmar
    Last Post: 08-10-2010, 11:24 AM
  4. YANMAR 1GM 10 Exhaust port corrosion
    By davidh5150 in forum Yanmar
    Last Post: 03-10-2009, 07:53 PM
  5. Replies: 3
    Last Post: 03-09-2009, 09:24 PM
