Results 1 to 3 of 3
  1. #1
    Default sOld 40 Tracker Pro Series 5-speed function issue
    Hi, I am new to this forum and I would first like to thank you for being here. I feel there is hope to solve a minor issue with the speed control system on an Old 40 Tracker Pro Series, which is a 5-speed. I just bought it, but it came without a manual, and the web does not give up its secrets on these older models. It is an electrical problem I hope to fix that will also MAYBE cure another concern I have with it.
    Here is what it is doing instead of what it should be doing. It currently has 3 speeds instead of 5.
    Speeds 1 and 2 are identical. I am hoping it is running in 2nd speed RPM in 1st because it seems awful fast for 1st speed. I hope a fix will result in 1st gear being much slower.
    Speed 3 is faster than 2, as it should be.
    Speeds 4 and 5 are identical, and faster than 3, as they should be.
    I'm hoping the selector switch is the problem and it is available online. So far I haven't been able to find any information regarding an electrical diagram or parts diagram.
    Any educated thoughts are greatly appreciated, and thanks again for being here!
    AND Happy 4th of July!
  2. #2
    Join Date
    Sep 2006
    Location
    Baton rouge, La, USA
    Posts
    2,501
    Default Re: sOld 40 Tracker Pro Series 5-speed function issue
    you have two threads going on this..delete this one..
  3. #3
    Quote Originally Posted by papyson View Post
    I tried to find out how to delete this one once I realized I had 2. I did not see any delete option but then I am new to this forum. Thank you for any suggestions to help resolve my mistake.
    Don
Similar Threads
  1. Mercury Tracker Pro Series 40hp 4 cyl. info. needed.
    By dillon in forum Mercury Mariner Outboard Forum
    Last Post: 04-20-2014, 03:40 PM
  2. Replies: 1
    Last Post: 07-15-2013, 11:32 PM
  3. 1998 Tracker Force Power Series
    By bigNrich in forum Chrysler Force Outboard Forum
    Last Post: 04-01-2011, 04:49 PM
  4. Tracker Force Power Series 120 HP 1998
    By big iron in forum Mercury Mariner Outboard Forum
    Last Post: 04-18-2010, 12:42 AM
  5. 40hp pro series tracker 1995
    By tal55lyd in forum Mercury Mariner Outboard Archive
    Last Post: 03-09-2008, 08:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
