Click for Ford Lehman manuals!
Results 1 to 4 of 4
  1. #1
    Default Ford Lehman 120 won't exceed 1500rpm when in gear
    Hello, I recently changed oil and replace an old valve on fuel tank that was sucking air. Boat has been setting for two months and just set out from Marina. When in gear the port engine will exceed 1500rpm but it will rev up at in neutral. Any suggestions? Jim
  2. #2
    Default Re: Ford Lehman 120 won't exceed 1500rpm when in gear
    Hi jim, sounds like fuel filters or stop solenoid over adjusted, not allowing fuel rack to move to full fuel.
    Charlie w.
  3. #3
    Now I have found no fuel or air coming out of the fuel return line and excessive fuel consumption. Filters have been changed.
  4. #4
    Hi jeccost, return line only sends about a cup of fuel back to the tank in an hour. Check your engine oil for fuel dilution==possibly bad lift pump.
    Charlie w.
Similar Threads
  1. FORD LEHMAN
    By Sea blue in forum Ford Lehman
    Last Post: 10-17-2015, 04:26 PM
  2. Ford Lehman SP 275
    By jejuda in forum Ford Lehman
    Last Post: 08-20-2013, 06:22 PM
  3. 120 ford lehman
    By peter_cameron in forum Ford Lehman
    Last Post: 05-05-2011, 06:53 PM
  4. Replies: 2
    Last Post: 10-08-2010, 12:53 AM
  5. Ford Lehman
    By gregggrundon in forum Ford Lehman
    Last Post: 11-16-2007, 02:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
