Results 1 to 11 of 11
    Default Engine Rebuild-Can't get above 2000 RPM?? Please help!
    So I recently purchased a 1993 Chris Craft Concept 185 with an OMC Cobra 3.0 engine. As it turns out, it had a cracked engine block (that the previous owner "didn't know about") and I ended up rebuilding the engine and replacing the block. I've had it out twice this past week trying to break it in, and I can't get the engine to exceed 2200 RPM, when it's in the water. I noticed it was low on outdrive oil, so I topped it off and ran it on the ears and I was able to get it straight to 4000+. Fluids are good, head was good, pistons and rings are new, harmonic balancer is new, new gaskets, it's been timed, so I can't figure out where the hang up is. I had it to a shop to have it aligned, so I trust that they did it correctly, but I witnessed some of their work and I was extremely shocked and dissatisfied, so I'm not ruling an improper alignment. Any tips would be greatly appreciated. Thanks.
    May 2007
    Kawarthas
    3,224
    Default Re: Engine Rebuild-Can't get above 2000 RPM?? Please help!
    start with a compression test. that'll rule out things like valve setting and any sort of ring/piston issue and you can look for water in the cylinders see if the spark plugs show anything weird.
    then triple check timing, then on to the fuel system.
    alignment doesn't have anything to do with low power, nor does drive level. Take 2 pistons out and it'll still rev to 4k in neutral. Power issues only show under load.
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
    May 2010
    DC Burbs/Maryland Eastern Shore
    1,239
    Fueling. As in, you aren't getting enough....
    Practicing the ancient art of ren-ching
    It seems like it's getting plenty of fuel. Once it reaches 2,000 RPM, it reacts as it should. If I keep applying throttle, it bogs the engine and sounds like it's getting more fuel than it can burn and doesn't increase speed, power or RPM.
    May 2010
    1,239
    I don't know how you measure fuel flow by ear, but in any case I would suspect the carb before anything else. It starts and runs, idles and accelerates. Then it gets to a certain point and "runs out of gas".
  6. #6
    Sep 2008
    Maryland - USA
    7,103
    does the timing advance as it's supposed to?
  7. #7
    Apr 2016
    barnegat NJ
    2,908
    Inspect a few plugs that might give a clue, running rich or lean.
  8. #8
    Jun 2008
    Island Heights, NJ,
    2,749
    re:" rebuilding the engine and replacing the block"... and the cam ???? original to your boat or came with new block?
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  9. #9
    Jun 2009
    Carbondale, colorado, usa
    24
    I am in the same boat ! I have twin 3.8 liter 4 bbl OMCin a 245 sea ray. Port motor purrs like a kitten at idle, timing advances properly, points were set with a dwell meter,new carb. On the water it runs good up to 2000 rpms and then bogs down and runs like crap. Did you find your problem?
  10. #10
    Mar 2009
    Portland, Oregon,
    9,718
    Quote Originally Posted by makomark View Post
    I'll second that question!
    If the ignition system is not delivering the correct progressive and total advance, at the prescribed RPM, the engine will not produce enough power.
    And by the way, I would quit running it until this is sorted out.
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
  11. #11
    I would be willing to bet that If you watch your timing light as you increase the throttle that the spark disappears around the point that it starts to run poorly.
  1. 2000 Mercury rebuild help!
    By Clint1395 in forum Mercury Mariner Outboard Forum
    Last Post: 12-18-2014, 07:54 PM
  2. 2000 200hp Evinrude will not start ICM/ECM rebuild or replacement
    By micoates in forum Outboard motors archive 2000-2004
    Last Post: 04-16-2013, 09:36 AM
  3. 2000 50hp tilt/trim rebuild
    By boerne14 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-02-2012, 04:01 PM
  4. What is a good price for transom rebuild? 2000 4.3L
    By moondrifter in forum Mercruiser Sterndrive Forum
    Last Post: 06-09-2011, 07:54 AM
  5. 2000 Mercury 200 HP rebuild ? No compression on one cylinder
    By Gonafixit in forum Mercury Mariner Outboard Forum
    Last Post: 02-20-2011, 02:07 AM
