Results 1 to 7 of 7
    Default 1968 Sears/Eska 3.5 motor oil and water pump?
    Hello we just inherited a 68 eska 3.5 HP out board model number 217 59860. Its been sitting for about 20 plus years. Before storage all fuel was drained, we put fresh fuel mixed at 16.1 it fired up after about 12 pulls. we let it run for about 10 or 15 seconds and shut it off. My question is i cant see a place to add or check the motor oil. Also its air cooled so im assuming it doesn't have a water pump. We are also looking for an owners Manuel. Thanks in advance
    Apr 2016
    barnegat NJ
    3,141
    Default Re: 1968 Sears/Eska 3.5 motor oil and water pump?
    2 strokes do not have a crankcase,oil is mixed with fuel to lubricate engine
    I was looking at it more like it was a lawnmower engine. This makes sense as I cant see a place ro add or check it. I guess its time to run it a bit longer. Thanks
    Apr 2016
    barnegat NJ
    3,141
    no problem,just trying to help
    Before I put it in the water I will change the fuel hoses, As they are leaking. Thanks again I appreciate your help.
  6. #6
    Dec 2015
    maplevalley WA
    4,921
    Go to sears parts direct and in the model number enter 21759860 for part numbers it does have a water pump to keep the exhaust cool mostly.
  7. #7
    thank you I will see if they have a manuel
  1. sears/eska no water pump
    By maximoo in forum Eska Outboards
    Last Post: 08-04-2014, 07:34 PM
  2. Replies: 3
    Last Post: 07-30-2014, 05:47 PM
  3. Eska water pump
    By 65novadude in forum Eska Outboards
    Last Post: 07-25-2009, 10:27 PM
  4. Sears eska 99 outboard motor overheating
    By toadfuss in forum Archive 2003-2009
    Last Post: 05-22-2007, 09:29 PM
  5. 99 Horse Eska Motor water pump questions
    By Jon Robert in forum Archive 2003-2009
    Last Post: 11-03-2006, 05:57 PM
