MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
Thread: prop help
    Default prop help
    I have bought a 18 ft. pontoon with 1999 merc.50 that runs great,it has alum. prop F10.13x15p, on the foot is a sticker that says 12x22 1.83:1,
    At wot tach is showing 4200 rpm. and gps shows 17.3 mph. Sticker on engine says 5500 rpm, It is time for a new prop and looking for advice on what to use, Being a man I would like more speed,but I do not pull tubes or anything,used solely for cruising,I am looking to do what is best for my engine.Thanks for help.
    Apr 2016
    barnegat NJ
    2,968
    Default Re: prop help
    Is tach accurate,thats alot of boat for that motor,a less pitched prop will give higher rpms and less carbon buildup in engine,and longer life on same,
    as far as I can tell tach is accurate,there are 18 and 20 ft. pontoons everywhere here with 50 h.p motors, I was thinking of probably going with 11" pitch, but not sure.
    Looking for input cause I certainly not expert, Thanks
    Apr 2016
    barnegat NJ
    2,968
    ask other boaters what pitch& diameter there using with same hull&motor.according to theory 1 inch of decreased pitch will give approximately 100 rpms.
    11" pitch sounds a good idea , depending on the load of the pontoon. Empty I would sggest 121/2" which should bring the motor better to live and increase speed.
    13" diameter is also a lot for that motor!
  1. Prop burning - Cavitation - Prop Singing on Duo Props
    By Chris Rohde in forum Volvo Penta Gas Engine Forum
    Last Post: 05-30-2015, 06:56 PM
  2. e15rcde prop bushing bad? prop spins on prop shaft while in gear
    By rockfisher805 in forum Johnson Evinrude Outboard Forum
    Last Post: 08-15-2014, 01:09 PM
  3. Prop size question and off shore style prop on a through hub exhaust?
    By H2oallyear in forum Propeller Selection and Replacement
    Last Post: 07-25-2014, 07:07 PM
  4. Volvo Penta Duo Prop DPS Prop Installation
    By njfishing in forum Volvo Penta Gas Archive
    Last Post: 04-30-2009, 10:05 AM
  5. Trying to determine diameter and pitch of prop on 85HP Johnson from number stamped on prop
    By Bob Padowicz in forum Johnson Evinrude Outboard Archive
    Last Post: 07-29-2006, 11:27 PM
