Can aluminum lower pump case driveshaft hole be epoxied?
ba_50
This m50D was in salt water and has some pitting in the driveshaft hole. Is there an epoxy that can be used to smooth it up? Maybe a little lock tite around the new seal would work? Thanks.
I took a closer look and slid the part over the driveshaft and was surprised it fit so loosely, so the pitting won't matter there. It is a little rough where the seals were but I don't believe it will be a problem after all. Bob
