2004 Johnson fourstroke
Dirtbikerrj
I have a 2004 200 hp Johnson four stroke. Runs good for a while then it starves for fuel. If you catch it in time you can pump the primer bulb and it will come out of it for a while and do it again. I'm guessing it's either a weak low pressure fuel pump or the low pressure pump isn't cycling often enough. I tried running it off a six gallon tank and the same thing happened.
