Hi,
My Mercury 140 (1980 or 81) motor came with the old-style Tilt & Trim system that has 2 rams and a hydraulic pump with a square reservoir mounted in the boat, with hoses going to the rams from there.
It currently trims down but not up and I have the issue narrowed down to the motor -- everything else seems to work electrically, but when I try to apply power directly from +12V to the motor's "up" connection, bypassing the solenoid, it does nothing and heats my jumper wire up to the melting point within a second. So most likely the motor is shorted out.
There are various 3rd-party motors available from Arco, Prestolite, and API, they all include the motor and reservoir only and you attach them to your existing pump, valve body, etc.
Has anyone done this procedure? How hard is it to replace? I'd like to know what I'm getting into before I drop $100-200 on a new motor. I can also get a new entire pump assembly but that gets closer to $500.
Thanks!
Thanks!
