[FONT="]Hello all. I was hoping to get some help with my Alpha one gen 2 not shifting. My impeller imploded on my first run of the season. I removed the outdrive to replace the impeller. I found the shutters in the exhaust path as well as the melted plastic water tube guide. Also the top of the sear carrier under the water pump looked worn on the top so I replaced it. It all went together well until I noticed that the prop wasn’t locking in gear no matter what I did. I searched this site and checked the usual things with no luck and wound up dropping the lower half. The shift shaft had very little resistance when turned and I could pull it up out of its seat. I removed the two screws on the shift shaft bushing mount and found that the clip holding the rod down was not in its groove. Now with the rod our of its bushing and without the clip I am unable to shift manually. There is no resistance. I can spin the shift rod around usually without going into gear. If I fool around with it long enough I can get it to go into forward I think (prop locked going counter clockwise.) But it takes a lot to get it there. The splines on the shift rod look fine to me. I should also mention that my son knocked the lower half over on my garage floor right before I was going to put the two halves together. It didn’t fall on any of the shafts but it was jarring at least. Any help would be appreciated[/FONT]
